battery issue nd heating problems
(Topic created on: 10-01-2017 12:26 AM)
RahulSharmaa
Secure Folder
Is anyone S7 edge and having battery drainage problem and heating issue always
3 Comments
AL3X
Secure Folder
you probably have so much apps running in the background or you have a battery draining apps
RahulSharmaa
Secure Folder
i don't think so that so much apps afe running in the background
admin_
Secure Folder
Thank you for your query. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
