heating problem while using camera
(Topic created on: 04-26-2020 09:26 PM)
SPHULARI
Pune
Hi
I am experiencing heating camera stopping after 8 to 10 clicks
I hv to just stop taking photos and it drains battery like which I never experienced
Pls advise same has been experienced by some of you and whats the solution for same
Thanks
B regards
Santosh
5 Comments
Not applicable
Pune
delete extra apps, 2nly if you had put the camera under the setting of allowing background activity if you have applied that setting then kindly turn on the allow background activity under app info page of camera app
SPHULARI
Pune
thanks for quick feedback... kindly explain background activity settings part
Not applicable
Pune
open settings >> scroll down >> then find the apps name under setting >> then see scroll down until you see camera app >> click the camera app >> then see the second option called battery and check the option is off or on if off then turn the option on
or
the second way is to tap and hold the app icon under app drawer or in the home screen you will see the option of app info then follow the above steps
Not applicable
Pune
follow the screen shots and mark my comment as solution via three dot menu over my comment
as well
SPHULARI
Pune
thanks ... manage to set background activity restrictions to others apps too..
hope it will help now to reduce heating and camera stoppage
