Auto restart problem
(Topic created on: 01-09-2022 02:30 PM)
dnyansagar
Beginner Level 3
Pune
Samsung a50 has been automatically frozen and restart automatically  please help
8 Comments
moarshad
Pune
Mobile storage space free
YoursTechGuy
Pune
It might be due to low storage space. Try creating a backup and factory data reset your phone and restore your data after reset. It will solve most of your issues.
dnyansagar
Beginner Level 3
Pune
This is for samsung a50 or m21
YoursTechGuy
Pune
Works for all of the phones with freezing and auto restarts problem. Make sure you backup your data before performing a factory data reset.
४UNKNOWN४
Pune
Please contact service center
Sid_Karna
Pune
please check out this post
https://r2.community.samsung.com/t5/Galaxy-M/ALERT-Those-who-have-restarting-problem-should-follow-t...
Accept the solution by clicking on the 3 dots on top of my comment, so that it will be helpful to others too.
anoymous_user
Pune
Go to setting then device care then care report then turn off auto restart
If u got the solution , click on 3 dots on this comment and accept solution
cs-member13
Expert Level 4
Pune
Dear Samsung member,
Kindly use a genuine Samsung charger.
Note: We always recommend using a genuine Samsung charger for charging your device.
There are two methods to disable the auto-restart function
Method 1
Please follow the below steps:
Step1: Navigate to the app's screen and tap on Settings.
Step2: Tap on General management.
Step3: Tap on Reset.
Step4: Disable Auto restart (if enabled).
Step5: Auto-restart disabled.
Step1: Go to "Settings"
Step2: Tap on "Battery and device care"
Step3: Tap on Three dots
Step4: Tap on "Automation"
Step5: Disable "Auto-restart at set times" if enabled
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback >Error report).
Warm regard,
