How to Fix Wi-Fi and Bluetooth Not Working Issues on Android 14
(Topic created on: 10-07-2023 07:15 AM)
Sandeep_Gautam
Promotions
The new Android 14 has been rolled out by Google, and it comes with a plethora of new and intriguing features that you can look forward to. There are many noteworthy features like lock screen customizations, auto-confirm locks, and more. However, all these features will count for nothing if the basic functionalities don’t work properly. Among those issues that have been causing trouble include Wi-Fi and Bluetooth Not Working issues. If your device is having frequent dips in network connectivity or is not able to connect to headphones or Android Auto, then there are workarounds.
If you’re looking for ways to resolve these issues, then this guide will be helpful. In this guide, you will get to know how to fix Wi-Fi and Bluetooth Not Working issues on Android 14.
How to fix Wi-Fi Not Working Issues on Android 14?
Method 1: Restart your device
  • Press the Power button to open the Power Menu
  • After that, tap on Restart and then wait for your device to reboot
  • While that is happening, you should also restart the router
  • Once your smartphone boots up, check if this fixes the Wi-Fi Not Working issue
Read It More: How to Fix Wi-Fi and Bluetooth Not Working Issues on Android 14
4 Comments
cs_member10
Promotions
Dear Samsung Member,
Thank you for sharing this. We appreciate the time and effort you have spent sharing your valuable comments.
roufi
Promotions
Hi
In my phone samsung f23 5g wi-fi and Bluetooth not working and mobile restarting continuously
Can you solve my issue
My mail ID is roufisk@gmail.com
ifrah2003
Promotions
Did your issue slove? Please tell me my brother is having same issue
WIFInotworking
Promotions
Hi
In my phone samsung f23 5g wi-fi not working and mobile restarting continuously
