system UI problems
(Topic created on: 11-09-2018 12:19 PM)
shree1
Beginner Level 4
Others
hi guys I need a help cause my j7 prime device is showing problems after the oreo update..its showing System UI has stopped and the screen gets dark and becomes unresponsive..I need to restart it with difficulty everytime ..please someone provide a solution for this problem...
7 Comments
wasee
Others
Back up data and do a factory reset and keep your fingers crossed
dvickyiest
Others
can you back up??
dvickyiest
Others
seem your download is corrupted. take it to samsung service centre.
Shiv9564
Others
wasee is right, you should try factory data reset.
APSINGH
Others
take it to service centre and update the phone by System
Daasarathi
Others
Plz restart the phone in safe mode and delete the files which are corrupted, restart again
AbhiS66
Others
Your firmware might have been corrupted.Try factory reset for once,If it doesn't work then either you can take the phone to nearest service center(Belive me,they fix firmware problems immediately,you will get your phone back in an hour) or you can use odin, get latest firmware from sammobile and flash it to your phone to get it working again.
ps:- There's a small chance of bricking your phone if you flash incorrectly.
Hope this helps :)
