justo5
10-12-2020 04:33 AM in
Others
I have S6edge. I flash it(hard reset) but before i delete Google account. Now samsung accout after putting email n password doesnt go through. And my usb port is not working to reinstall os
Solved! Go to Solution.
10-12-2020 07:29 PM in
OthersHi justo5
Please take the device to the service cenetr for a software reload. To locate a service center near you, please visit the link below:
Whether it's a product repair or just some help and advice. There are authorised support centres across the ZA that can help you.
OthersHi justo5
