battery problem interactive checks not working
(Topic created on: 09-05-2020 03:57 PM)
dineshbabu1980
Others
Hi friends and experts ,
Today after waiting long (due to covid) my battery replacement done almost 15 days from the official service center
But still my autocheck and interactive check shows battery is weak to be changed
How to know whether I got proper  battery , kindly help me with this issues
Thank you all in advance
10 Comments
Not applicable
Others
it's not any battery issue ..it's software glitch just ... if you factory reset then this will goes this happend with many users before... either factory reset or reflash software via service center
Others
will do factory reset and get back to you, thank you
Others
same response even after factory reset sir
Not applicable
Others
ok then also it's not any issues regarding battery bro ...when next security patch will arrived then this time flash that firmware from service center your issue will solved ..thatswhy told same issues there in many person...it solved
Not applicable
Others
see this problem solved long before with another user 👉 it's nothing but software issue ...i gurrentee you
Balu332
Others
Other way to test is install accu battery and see the estimated capacity after 5 - 10 charging cycles if it is near to design capacity than we can say your battery is new..
Others
nice idea will try it , thank you
Others
thank you sir, have a nice time ahead
cs-member13
Expert Level 4
Others
Dear Samsung Member,
We apologize for the inconvenience caused to you. We would request you to kindly raise your concern under the Ask Question section from Samsung Member Application with more details, so that we can help you out with this.
Samsung member application > Click on get help > Send feedback > Ask question.
