WiFi connection problem
(Topic created on: 07-09-2021 07:48 PM)
Mustasim
Others
Could not authenticate connection  এটা দেখাচ্ছে ।
M02s
5 Comments
Others
Click on forgot network then connect again and do a router restart and
Restart your galaxy device
Mustasim
Others
This is not happening even after doing it
Mustasim
Others
That way I did it but the same problem is happening
Others
Dear Samsung Member,
Please perform the below mentioned steps to resolve the issue:
* Forget the Network: Go to apps screen >Settings >Connections > Wi-Fi >Wi-Fi network >Tap and hold the Wi-Fi network that you're having trouble with until the menu allows you to select Forget Network.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Mustasim
Others
