Top issues, few updates, and way forward :)
(Topic created on: 05-12-2020 07:22 PM)
ShivZen
Others
Hi All,
Due to lockdown, our customer care centers were functioning with limited capacity. While we’re trying our best to bring things up to speed, here are responses to some of the top issues you might be facing:
  1. Delay in updates: There’s a delay in rolling out updates due to lockdown. For following devices the FOTA will be opened after the lockdown is lifted:
    1. Galaxy A6
    2. Galaxy-A9-2018
    3.  Galaxy A10
    4. Galaxy A10s
    5. Galaxy A70
    6. Galaxy-A9-2018
    7. Galaxy Fold
    8. Tab S6
  2. Galaxy S20 heating issue, lag while usage, and camera focus:
    1.      We’re collecting evidences from users to help us resolve this issue. We would request you to go to Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail.
    2.      The update which addresses above mentioned issues will be rolled out after lockdown gets over, most probably around month end.
  3. Flagship updates: There’s a delay in rolling out updates due to lockdown. And, we’ll release a schedule soon! Be sure to keep an eye out on the Notice section.
  4. Galaxy S10+ heating, battery life, lag while gaming:
    1. Some issues will be resolved in the next update.
    2. We do not have error logs so we can look into what might be causing this issue.
    3. We would request you to go to Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail.
  5. Galaxy S9+ camera issue: The camera issues will be resolved in the next update.
  6. Network/connectivity issue:
    1. This issue was prevalent last year but we do not have any new error reports with this issue.
    2. We would request you to go to ‘Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail.
  7. Galaxy A50 fingerprint issue: Please wait for the next update
  8. Galaxy A50 camera issues: We do not have any new error reports with this issue. We would request you to go to Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail.
  9. Galaxy A50 lagging issue: We do not have any new error reports with this issue. We would request you to go to Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail.
  10. Note 10+ issues like lag while using apps, poor battery performance, and heating issues:
    1. So far, the error logs we received indicated that the users were using the smartphone while charging, or unusual screen-time or unusual app usage like playing games, watching movies for extended period of time or multiple actions executed at the same time- which was a common behavior during lockdown.
    2. If you face issues where your Galaxy smartphone is heating up despite above mentioned activities, we request you to please submit your error logs.
    3. To submit error log, go to Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail.
  11. Auto-restart of device when certain app is fired: This issue will be fixed in next update.
  12. Galaxy M31 lagging issue: There’s no error log that supports this. We would request you to go to Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail.
  13. Mobile data not working properly: During lockdown, many network providers were struggling with the bandwidth. From the few reports we’ve received the issue was due to network provider and not the device. Having said that, request you to please submit your error logs, so we can investigate more.
  14. Heating issue:
    1. This was one of the most reported issues in the past month. Unfortunately, we do not have error logs that indicate that this issue was due to device and not due to user behavior.
    2. We would request you to go to Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail.
    3. So far, the error logs we received indicated that the users were using the smartphone while charging, or unusual screen-time or unusual app usage like playing games, watching movies for extended period of time or multiple actions executed at the same time- which was a common behavior during lockdown.
    4. If you face issues where your Galaxy smartphone is heating up despite above mentioned activities, we request you to please submit your error logs.
  15. Battery discharge idle drain issue:
    1. Please run a quick device self-diagnosis and see if the battery is working fine.
Important note: We can only fix the issues, if we receive error logs that capture the issue well. Here are some tips to capture good error logs:
  1. Capture the error logs within 3 minutes of the issue occurrence.
  2. Go to the ‘Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail.
  3. If you do not get a response within 72 hours of submitting an error report, please let us know with a screenshot. Please reach out to Admin, community managers, and BAs.
We hope this answers some of your queries and going forward, every week or two, we’ll call out for unanswered error reports, and top issues, and we’ll try our best to give you an update.
We’d like to thank our BAs for helping us collate the top issues, and we’d like to thank all of you for being patient with us.
We hope you, your family and friends are keeping safe! Looking forward to your comments/suggestions on how we can make this community better :)
207 Comments
Others
Use mx player.
Others
Mx player fries speakers... 😐
Others
Haan kya, mai to 3 years se use krra, meko to aisi problem kabhi nahi aayi, kisi bhi phone ke saath🤔.
cherrychikoo
Others
when will Samsung Galaxy A505F get Android Q update?
Vtech
Others
bhul jao nahi milne wala
THE(YSAMSUNG)ARE INDIRECTLY SAYING
updates chahiye to apne sarkar ko bolo lockdown hatane ko yaha hamara dhandha ni ho raha h is lockdown k karan or tumlogo ko updates ki pari hui h bhag yaha se nahi milega updates....
THESE ARE NOT MY WORDS BRO...
himansh221
Others
after lockdown lifted whoo what if lockdown extended till 1 july so update available after 2 month🤔🤔🤔
jayeshv
Others
I have a blurry rear camera issue in Samsung Galaxy j8
Others
Hi All,
Delay in updates: There’s a delay in rolling out updates due to lockdown. For following devices the FOTA will be opened after the lockdown is lifted: Galaxy A6 Galaxy-A9-2018  Galaxy A10 Galaxy A10s Galaxy A70 Galaxy-A9-2018 Galaxy Fold Tab S6 Galaxy S20 heating issue, lag while usage, and camera focus:      We’re collecting evidences from users to help us resolve this issue. We would request you to go to Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail.      The update which addresses above mentioned issues will be rolled out after lockdown gets over, most probably around month end. Flagship updates: There’s a delay in rolling out updates due to lockdown. And, we’ll release a schedule soon! Be sure to keep an eye out on the Notice section. Galaxy S10+ heating, battery life, lag while gaming: Some issues will be resolved in the next update. We do not have error logs so we can look into what might be causing this issue. We would request you to go to Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail. Galaxy S9+ camera issue: The camera issues will be resolved in the next update. Network/connectivity issue: This issue was prevalent last year but we do not have any new error reports with this issue. We would request you to go to ‘Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail. Galaxy A50 fingerprint issue: Please wait for the next update Galaxy A50 camera issues: We do not have any new error reports with this issue. We would request you to go to Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail. Galaxy A50 lagging issue: We do not have any new error reports with this issue. We would request you to go to Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail. Note 10+ issues like lag while using apps, poor battery performance, and heating issues: So far, the error logs we received indicated that the users were using the smartphone while charging, or unusual screen-time or unusual app usage like playing games, watching movies for extended period of time or multiple actions executed at the same time- which was a common behavior during lockdown. If you face issues where your Galaxy smartphone is heating up despite above mentioned activities, we request you to please submit your error logs. To submit error log, go to Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail. Auto-restart of device when certain app is fired: This issue will be fixed in next update. Galaxy M31 lagging issue: There’s no error log that supports this. We would request you to go to Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in detail. Mobile data not working properly: During lockdown, many network providers were struggling with the bandwidth. From the few reports we’ve received the issue was due to network provider and not the device. Having said that, request you to please submit your error logs, so we can investigate more. Heating issue: This was one of the most reported issues in the past month. Unfortunately, we do not have error logs that indicate that this issue was due to device and not due to user behavior. We would request you to go to Get Help’ section, click on ‘Send Feedback’, and then click on ‘Error Reports’. Proceed to select your issue and write to us in deta
harshkht
Others
How can other countries are getting update instead of lockdown and only in India there is a problem due to lockdown?
BUNTY22
Others
U peoples are alive?
o my god i think u peoples are dead.
whole world even usa/italy mostly covid affected countries provided continue updates even pakistan/Bangladesh got regular updates but u peoples have only excuse.
samsung is losing their market remember within some time u peoples salary also affected only one coz customers unsatisfied.
Only for u peoples lockdown & other countries they are working they love their job even they work from home but in india u peoples loves excuse & holiday.If lockdown extended 1 month more then we have to suffer one month more.Great.
Indian lazy & excuse people.
Economy was trashed but u peoples continue done excuse & lazyness with your work.
Peoples don't have enough money to purchase phone right now & this will remain for atleast 1 year.
If peoples unsatisfied then who purchase samsung's costly product
Due to excuse u peoples surely lose your job.
who tells samsung to push Corrupted android 10 in A50 device?
Many other devices are also full of bugs coz of your android 10.
we peoples thought samsung's people are dead due to covid.
