🔥Reduce heat by 10% on S22UltraGen1 and every device running 4.1,4.1,3.1fullUI
(Topic created on: 04-09-2022 06:32 AM)
Others
<html>
We all know here at India its summer and is so hot 🔥 humid so its normal to gadgets to heat🥵 even wearables are heated when charging. (example my buds pro,)
So here is a Small Tip to reduce heat 🔥 by 10%
*After All install follow the images I given below
( if you can't see this post images click the link on the comment section and open with browser by copy paste)
*do everything shown on the
images
Here:
Step 1
OPEN THERMAL GUARDIAN AND REDUCE THRESHOLD BY -2°
STEP 2
GO TO ADDITIONAL SETTING
THEN SELECT ALL OPTIONS
Click apply and done !
<b> All Set ! </b>
</html>
-ChoeHa-U♡
14 Comments
Others
Do the HTML commands work here?!
Edit- I tried making a post using the commands
Most of the tags like
don't work
However commands like (break like), (italics), (underline), (bold) do work!
When you see the post without clicking on it it shows the commands as they worked
When u click on the post it shows all the program u have put! Screenshot_20220409-083139_Samsung Members_2714_1649473299.jpg
Others
Great
mHappiee
Others
Yes, HTML tags work... But input from desktop mode is needed... It doesn't work from Members app
Others
Ohhhhh
Others
Yes !
Others
Thanks 😊
Roshan5
Expert Level 3
Others
Don't download and Install.APK Files.
Install softwares only from Google Play Store and Galaxy Store.
Others
Hey you can trust me
And
Apk downloading from APK mirror
Is safe as playstore
