C9 pro camera problem
(Topic created on: 03-31-2017 11:40 AM)
AkshayAky
Others
As i have purchased c9 pro its camera is not good working as compare to my old phone A7 2015 thus its updated version and new model while having 16 mp front and back while A7 have 5mp front and back 13mp thus its click more attractive than c9 pro
noise and blur comes while i click photos in low light and at night
so please help me i have spended 36900 on this phone and not get even good camera.
7 Comments
swapnil
Others
omg.... bhai samsung ko phone wapis kar do aur manhani kar do....
AkshayAky
Others
ese lete thodi hai woh
jayahir
Others
c9 pro se achha one plush 3t lele te
Samsung_India_
Others
Thank you for sharing your concern. Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device speeds may vary based on multiple outside factors.
1) Check the Picture size (Camera Capacity) in camera setting (It should be Max according to Camera Capacity)
2) Turn on the Auto Flash (If Available in the Device)
3) Reset the Camera (From the Camera Setting)
4) Software update via FOTA,Kies or SMART Tool.
rjsri
Others
did all d above thing but still facing same front camera back ground blurry so pls fix samung d said issue asap
Others
yes bro facing same problem
AkshayAky
Others
ise acha to A7 2015 ka camera acha hai Dlsr jese pictures click hote hai
