Battery draining issue and charging speed issue Samsung Galaxy M30s
(Topic created on: 12-17-2019 04:54 PM)
Tikunwengsu
Others
It's not feels like 6000mah battery but I m pretty sure it feels or behaves like 4000mah battery why?😡😡😡😡 and my charging speed not improved so when you give next security patch updates fix these 2 bugs immediately I want security updates  and battery draining issue, charging speed issue immediately.....🙄🙄😡😡
8 Comments
MiraclePanda
Others
buddy mention your phone model when you make a post.
Tikunwengsu
Others
Galaxy m30s
Others
divise care me Jake battery graph send kriye
Tikunwengsu
Others
ish se kuch nhi hota hai performance iska 4000mah battery jaisa hai
Others
hota hai mai tumhare se compare krunga Kyon ki mera m30s me bhi 6000 mah battery
Tikunwengsu
Others
hum jada heavy use nhi karte lekin phir bhi main thoda sa heavy use karta hu thek hai aur hum aacha tarika sai samajte hai battery usage kaisa performance deta hai tum nhi samjhoge compare toh dur ki baat hai😂
Others
Hi there,
To resolve the issue please follow the troubleshooting steps provided in the given links:
For Battery Drainage:
http://www.samsung.com/in/support/skp/faq/1101689
For charging issue:
>Charge the device in switch-off mode.
>Charge the device with the other original charger.
>If available in your device than Enable fast charging (Scroll down notification panel>Setting >Device maintenance>Battery>3 dots (upper right corner) >Advanced setting>Fast cable charging>Enable).
>Perform Interactive checks through Samsung Members app (Samsung Member> Get Help> Interactive checks->USB/Charger).
For further assistance, register your concern in Samsung members app(click on “+“icon>send feedback>Error report/ Ask Questions)
Regards,
Team Samsung Members
Tikunwengsu
Others
Are you true Samsung Support??? 🤔🧐
