Monday (Last edited Monday ) in
Others- Mark as New
Tuesday in
OthersDear Samsung Member,
Step 1. Check your vehicle.
● Check your vehicle whether the vehicle or stereo is compatible with Android Auto.
● Make sure that Android Auto is switched on in your vehicle's settings. Consult your vehicle's manual or contact the manufacturer if you need further assistance with it.
● On some vehicles, Android Auto support was added in an update. If your car is listed as a supported model but Android Auto isn't working, try updating your infotainment system or visit your local dealer. Consult your vehicle's manual or contact the manufacturer if you need further assistance with it.
Step 2. Check your phone.
● If your phone is running Android 10, no need to download Android Auto separately.
● If your phone is running Android 9 or lower, you need to download Android Auto from the Play Store.
● Your phone connection must allow data transfers for Android Auto to function. When your device is connected via a USB cable, swipe down from the top of the screen and tap the notification from the Android system. Select the option that allows for file transfer.
Step 3. Connect and start.
● The connection between Android Auto and the vehicle is possible using a Bluetooth or USB cable, and the connection method may differ depending on the vehicle and manufacturer.
● Check if Android Auto is displayed on the display.
● While most USB cables look similar, there can be huge differences in terms of their quality and charging speeds. Android Auto requires a high-quality USB cable that is capable of supporting data transfers. If possible, use the original cable that came with your device.
● You can reset your device by following the steps:
3. If you do not remember the password, then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings. This will erase all data, including files and downloaded apps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application >> tap on Support >> tap on Send feedback >> Tap on Send icon >> select the appropriate category y >> type your query and tap on send).
