problem with bluetooth connectivity
(Topic created on: 10-02-2025 01:49 PM)
unni62
My Galaxy
with this f14 phone (android ver 15) i tried to connect sarkey edge ai hearing aid. i could pair the device but cannot establish connectio
at the sametime, with my galaxy m30 phone ( android ver 11) i was able to establish the connection via bluetooth
can you help me out with a solution
cs_member10
My Galaxy
Dear Samsung Member,
1. Reset App Preferences: Settings > Apps > Tap on More option or on three dots at the top right corner of the screen > Reset App Preferences.
2. If the issue is not resolved by above step, then: Clear “Paired List”: To clear tap on “Settings” option along with the paired device > Unpair.
3. Try and connect your device with another device:
4. If the issue is still not resolved, then “Clear cache and data” of Bluetooth app:
Go to Settings > Apps > Filter and sort > Show system apps > OK > Search apps > type ""Bluetooth"" > Tap on ""Bluetooth"" > ""Storage"" >""Clear cache""
Note: Clearing the app cache is like cleansing your apps. It will get rid of residual files that could slow down the app.
Tap on ""Clear data"".
Tap on ""OK"".
Note: Clearing the data will reset the app to factory default settings. Any personal settings saved on the app will be removed.
5. If the issue is still not resolved, update software:
Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now.
6. If the issue is still not resolved, Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
