Samsung Galaxy S23 FE Issues– Battery, Fingerprint, Heating & Delay in One UI 7
(Topic created on: 02-01-2025 11:51 PM)
PrasadNate
My Galaxy
Hi Samsung Members,
I’ve been experiencing several issues with my Galaxy S23 FE and wanted to see if others are facing the same problems.
  1. Battery Drain – The battery life has significantly worsened. Even with moderate use, I notice faster depletion compared to before.
  2. Fingerprint Scanner Issues – The fingerprint sensor is inconsistent, often failing to recognize my fingerprint or taking longer than usual.
  3. Overheating – The phone heats up even during normal usage, like browsing or using social media, and gets worse while gaming or charging.
  4. One UI 7 Update Delay – the S23 FE update seems to be delayed. Any official update on this?
Is anyone else facing similar issues? Any fixes or workarounds? Hoping Samsung addresses these problems in an upcoming update!
#S23FE #Samsung #OneUI7 #BatteryDrain #FingerprintIssue #Overheating
7 Comments
rita111
My Galaxy
You can replace the battery for free if you have warranty
Manish0024
My Galaxy
Yes bro
I have been experiencing several issues with my Galaxy S23 FE and wanted to see if others are facing the same problems.
Battery Drain – The battery life has significantly worsened. Even with moderate use, I notice faster depletion compared to before. Fingerprint Scanner Issues – The fingerprint sensor is inconsistent, often failing to recognize my fingerprint or taking longer than usual. Overheating – The phone heats up even during normal usage, like browsing or using social media, and gets worse while gaming or charging. One UI 7 Update Delay – the S23 FE update seems to be delayed. Any official update on this?
arun0811
My Galaxy
Yes me to but battery is not that much drain.
fingerprint sensor and heating issue are same.
May be in one ui 7 will fix this problems i think so
goodthings
My Galaxy
goodthings
My Galaxy
Your's most welcome to here.
cs_member10
My Galaxy
Dear Samsung Member,
We would like to inform you that there is no official date has been announced yet for a UI 7 update for your device. Please stay tuned until you receive any further notification regarding the same in the Samsung Member app under the notifications section.
We understand that you are facing multiple issues with your device. To ensure that we can provide you with the best possible assistance, we would request you please visit the nearest service center for a physical inspection of your device.
You can locate your nearest service center using this link: https://www.samsung.com/in/support/service-center/.
Avi2000
My Galaxy
Same issue I faced, too. Why is selling a faulty product to a customer still not being addressed? Totally one of the worst Samsung products(S23 fe) !!!
