Regarding my galaxy a35 heating and battery draining issue.
(Topic created on: 05-01-2024 07:27 PM)
Members_iBq4g2x
Beginner Level 5
My Galaxy
It heats a lot and drain battery faster even not connected to 5g. Compared to other samsung phone it is worse.  This was my first smartphone phone i didn't aspect such a problem from a samsung smartphone.
4 Comments
cs_member10
My Galaxy
Dear Samsung Member,
As per your concern, we would request you to kindly perform the following steps to resolve your issues by using the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
JithinAjith
My Galaxy
Settings 》Google 》Devices 》Turn off scan for nearby devices
Settings 》Connections 》More connection settings 》Printing 》Turn off default printing service
Device care 》Battery 》Background usage limit 》Deep sleeping apps 》 add apps
Settings 》Location 》Improve Accuracy 》Turn off Bluetooth and WiFi scanning
Ajay_das
My Galaxy
Call to customer care 1800407267864 Complaint dere battery draining issue, say next update plz recover
Panks173
My Galaxy
Yes, friend. I did it.
