battery problems
(Topic created on: 04-18-2020 07:43 PM)
shankersah
Beginner Level 3
Mumbai
My Samsung Galaxy A50 phone
Slow battery charging and hitting problems
Please help
5 Comments
AdvTamhankar
Mumbai
Do this Thing.
1. First Switch off the Phone, then Press and hold Power Button + Volume Up (Simultaneously), as Samsung Logo appears release the Power button but keep holding Volume Up.
2. "Android System Recovery" will appear, you have to control the functions with Physical buttons.
Select, "Wipe Cache Partition" with Power Button. Select "Yes".
Wait for the system cache partition to clear.
Select the Reboot option to return to normal device usage.
Hope it helps.
shankersah
Beginner Level 3
Mumbai
try this option but no problem solved
Bubluu
Mumbai
Check for the following reasons:
1.Charging USB cable might be damaged.Try with other cable
2.Try to charge your device with official samsung charger
3. Charging port may be damaged.
4. Battery may be damaged
5. Weak power source
If above reasons are not the issue i think you may wait and visit a service centre after this lockdown.Hope it helps you
Bubluu
Mumbai
Are you using the phone while charging? If so, you may also experience phone heating.When you use your phone while charging, it uses battery making it to charge and discharge at the same time.So phone may heat up.Try to avoid using phone while charging.Hope it helps you
cs_member10
Mumbai
Dear Samsung Member,
To resolve "charging issue " kindly follow the given below steps:
1)Check physical condition of USB cable:-Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc
2) Safe mode:-Power off the device > Press and hold the Power key for one or two seconds to turn on the device > When the Samsung logo appears, press and hold the Volume down key.
Note :-To exit safe mode restart the device .
Reset the device: -Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
Tap on Settings>Tap on General Management>Tap on Reset.
To resolve "Overheating" issue kindly follow the below link for details :- https://www.samsung.com/in/support/mobile-devices/why-the-heating-issue-occurs-in-mobile-device/
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
