12-31-2024 01:46 AM in
Jaipur- Mark as New
12-31-2024 02:26 AM in
JaipurStep 1: Analyze Battery Usage
1. Access Usage Data:
Navigate to Settings > Battery and device care > Battery.
Tap on View details for a detailed breakdown of battery usage by app.
2. Identify Problematic Apps:
Look for apps consuming excessive battery.
Restrict their background activity or uninstall them if unnecessary.
Step 2: Optimize Network Activity
1. Avoid Constant Network Searches:
Ensure your phone isn't endlessly searching for Wi-Fi or cellular networks.
2. Turn Off When Not in Use:
Disable Wi-Fi, Bluetooth, and location services when they're not needed to conserve power.
Step 3: Inspect Hardware
1. Charging Port and Accessories:
Check the charging port for debris or physical damage.
Use a different, verified charger and cable to rule out accessory issues.
2. Battery Health:
Consider having your device inspected by a professional to assess hardware-related battery concerns.
Step 4: Keep Software and Hardware Updated
1. Software Updates:
Even if you’ve recently updated, ensure there are no further pending updates.
Go to Settings > Software update to check for the latest version.
2. Hardware Maintenance:
If software solutions don’t help, contact Samsung Support for potential hardware checks or repairs.
Step 5: Repair or Replace
1. Samsung Support:
Reach out to Samsung Support for professional troubleshooting and guidance.
You may be offered a remote diagnostic service or the option to schedule a repair.
Additional Tips to Extend Battery Life
1. Power-Saving Features:
Activate Medium power saving or Maximum power saving modes to reduce energy consumption further.
2. Adaptive Battery:
If available, enable Adaptive Battery to optimize power usage based on your habits.
3. Optimize App Permissions:
Restrict location services and limit app permissions to only essential applications.
4. Widgets and Animations:
Minimize home screen widgets and animations as they refresh frequently and consume power.
5. Wait for Android 15 based One UI 7
* most of the content is AI based.
12-31-2024 02:40 AM in
Jaipur- Mark as New
12-31-2024 03:45 AM in
Jaipur- Mark as New
12-31-2024 04:06 AM in
JaipurDiagnostic Steps
1. *Safe Mode*: Boot your phone in Safe Mode to isolate if any third-party apps are causing the battery drain. To do this, long press the Power button until your phone restarts in Safe Mode.
2. *Battery Usage*: Check the battery usage pattern. Run the battery from full to approximately 15%, then head to the Device Care section under Battery to see which apps are consuming the most power.
3. *Power Management*: Some users have reported aggressive power management issues after the April update. Check if this is affecting your phone's performance and battery life.
Potential Software or Hardware Updates
1. *Software Updates*: Ensure you're running the latest software. Although you've mentioned you've updated to the latest version, double-check for any newer updates.
2. *Carrier Updates*: Reach out to your carrier to see if there are any specific updates or settings that can help improve battery life.
Repair or Replacement Options
1. *Visit a Samsung Service Center*: If none of the above steps resolve the issue, visit a Samsung authorized service center for further assistance. They can diagnose any hardware-related issues and provide repair or replacement options.
By following these steps, you should be able to identify and potentially resolve the battery backup issue on your Samsung Galaxy S24.
Please do check these links:
https://eu.community.samsung.com/t5/galaxy-s24-series/galaxy-s24-battery-drain/td-p/10435700
https://eu.community.samsung.com/t5/galaxy-s24-series/s24-poor-battery-life-and-quick-drain/td-p/100...
https://eu.community.samsung.com/t5/galaxy-s24-series/disastrous-battery-life-after-april-update-sam...
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
12-31-2024 07:58 AM in
Jaipur- Mark as New
12-31-2024 07:59 AM in
Jaipur
12-31-2024 04:14 PM in
JaipurDear Samsung Member,
As per your query, you have already done the possible troubleshooting steps on your device but still issue not resolved. So, we would request you kindly visit the service centre and inspect your device with the technical team end, they will provide you with all the information in a better way after inspecting the device physically.
You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
01-01-2025 12:17 AM in
Jaipur1. except essential apps, put all your apps into deep sleep mode, occasional notification apps in sleep mode
2. turn off unnecessary options like wifi scanning, bluetooth scanning, nearby device scanning
3. Turn off location, Bluetooth and nfc when not in use.
4. Use "light" performance mode if you want.
5. Restart device once in every week.
6. Screen timeout 30 secs
7. Turn on data saver under connections
8. Using 5g is upto you, but understand that will drain more battery. I'll suggest using LTE and use 5g whenever required.
9. I won't suggest using power savings mode since it restricts 120hz refresh rate, Use it if you wish.
Use this and wait for 3 days and inform if you find any changes.
01-03-2025 08:50 PM in
Jaipur
