Games Sound Problem
(Topic created on: 05-09-2020 04:27 PM)
Joshi_124
Gaming Hub
There is sound problem on My Galaxy M10 while I play pubg or pubg lite I think it was game launcher's fault but no it wasn't. I played game without launching it from Game Launcher but Real Sound come when I tap on recording without tapping on recording sound remains slow.
CAN Some one suggest the solution ?
7 Comments
Subhash12
Gaming Hub
Please check your apdet and heardreast this divice
Joshi_124
Gaming Hub
What ??
oyemukul
Gaming Hub
same in my s8.
Joshi_124
Gaming Hub
Did you find the solution?
cs_member9
Gaming Hub
Dear Samsung Member,
Kindly follow the below mentioned step to improve the performance of the device:
  1. Check device volume settings: Settings.> Sound & vibration.> Volume. Drag the volume adjustment bar left or right to increase or decrease the device volume.
  2. Check mute all sound option: Settings.> Accessibility.> Hearing enhancements.> Disable Mute all sounds (if enabled).
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > send feedback > error report/ask questions).
Joshi_124
Gaming Hub
nothing happened
Joshi_124
Gaming Hub
suggest something good
