Speed
(Topic created on: 03-22-2026 05:05 PM)
BManoj1
Galaxy Z
Interne speed on status bar are not showing
2 Comments
KunteAmith
Galaxy Z
This is not a feature of samsung phones. You can either use any 3rd part apps like glasswire or if you need it to be native, then it's in one plus devices.
If this comment helps you then click on 3 dot on this message and select accept solution. Thank you.
cs_member10
Galaxy Z
Dear Samsung Member,
As per your concern, we would like to inform you that Samsung devices do not display internet speed status. Moreover, we will note down your feedback for future reference.
