Problem with drop down notification panel
(Topic created on: 01-22-2024 05:57 PM)
msamiulislam
Galaxy Z
When I try to drop down the notification panel after I unlock it, every time it freezes for few seconds. After trying for few times to drop down, it comes back to normal state. My handset is z fold 4 5G and I have also update it to UI 6.0 to resolve. But, no change at all.
cs_member10
Galaxy Z
Dear Samsung Member,
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
Note: To delete files or uninstall apps that you do not use anymore, select a category under USER DATA. Then, tick items to select and tap DELETE or UNINSTALL.
Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
You can check the device in safe mode and for the safe mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
In case the issue persists, kindly share the report of the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
