Notification sound problem when device is closed
(Topic created on: 06-02-2024 02:37 PM)
Riyaz153
Galaxy Z
Hi,
So from yesterday, I am not getting any notifications tone when I close my Flip 5 even though I haven't put my phone on silent or anything. I do get notifications tone when phone is completely opened up. And also I have noticed that when the Mobile is closed, the media sounds are bit weaker. Any idea?
3 Comments
Umangmathur
Galaxy Z
Try optimising your memory and scan your device for any potential viruses also please check the notification settings of each apps and check sound equaliser and set every bit to highest. Hope that helps thanks.
Riyaz153
Galaxy Z
Hey tried using it, another thing I noticed that, while the flip 5 is closed, the speaker of phone isn't working properly
cs_member10
Galaxy Z
Dear Samsung Member,
Disconnect anything plugged into the headphone jack like, a selfie stick, headphones, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
Clear Sound Picker data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Picker> Storage> Clear data of Sound Picker.
Clear Sound Alive data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Alive> Storage> Clear data.
Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
