Battery drain issue
(Topic created on: 01-04-2025 08:16 PM)
gihmme
Galaxy Z
I am facing batery issues on my mobile galaxyzfold5 the battery is draining too fast
4 Comments
goodthings
Galaxy Z
goodthings
Galaxy Z
Your's most welcome to here.
Wodehouse
Galaxy Z
Try few power saving steps
1 Enable power saver.
2 Change display to natural
3 Shift performance profile to light
4 Enable extra dim
5 Reduce gaming
6 Reduce media payback
7 Record video in FHD
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
cs_member10
Galaxy Z
Dear Samsung Member,
We regret to hear about your experience with our product.
To fix battery drain issue please use the link to perform some easy troubleshooting steps: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps:
3. If you do not remember then reset (Forgot password) your Google account.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
