One ui 7 battery drain problem
(Topic created on: a week ago)
cs_member10
Dear Samsung member,
We want to inform you that we are currently unable to access the shared link regarding the ongoing issue. Please perform the below-mentioned troubleshooting steps, these may help in resolving your device battery drain concern.
9. Reset the device:
IMPORTANT:
• For this:
