Resolved! Solved
Bug Problem Please Help
(Topic created on: 01-19-2022 05:27 PM)
KP2128
Galaxy Store (Apps & more)
When I tap Back Button I am unable to close the app
Pressing bck button several times all not helping me
Please suggest somethin What can do ??
Goto Settings > Apps > One UI home
And clear that Apps data. Lemme know if that works.
24 Comments
Not applicable
If no button is working!
Then may be you pinned this app
Press menu button and back button at the same time
Do you have 2 samsung devices??
KP2128
That's not the case
Suggest something else
Green_Grass
Expert Level 3
100% working solution
Press and hold power button for 10 seconds
Don't click anything
Just press for 10 seconds
Your device will restart forcefully
And it will solve
Not applicable
Press and hold the Volume down and Power key for 7 to 10 seconds
Green_Grass
Expert Level 3
No need
Just press and hold power button
It works
Not applicable
Not working
I tried
Yah power + volume down for 7 second make force restart
KP2128
If I press home button then I can exit the app
The problem is after pressing the back button the app should get closed but it doesn't, how to solve this ??
Back button not working, on which security patch update and device?
