very low call sound
(Topic created on: 09-18-2020 11:20 PM)
piyushpasu
Very low call sound after last software update on my galaxy s9
Even with earphone the call sounds are very low
5 Comments
Tamim87
please install Dolby Sound system
Not applicable
what Dolby will do with phone call 🙄? and it's pre instead in s9
piyushpasu
it already comes installed in galaxy s9
Not applicable
bro just flash the last firmware from samsung service center..your problem will solved .... i am using s9 and I did the same
Samsung_Support3
Dear Samsung Member,
Please perform the below mentioned steps to resolve the issue:
* Check device volume settings if its full or not.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
