terrible battery life on s7 edge😡😠
(Topic created on: 10-30-2017 01:54 PM)
whiterfang
while the phone was runnung on marshmallow.i used to get screen on time about 6.5 to 7 hours with 20%left. with wifi and mobile data switching. now in nougta the result is very bad as you can see its about 2.3 hours only using wifi and not even mobile data. please fix this issue samsung. i have to charge my phone 2 to 3 times a day.e8495194-0eb4-4a79-ad1c-cb4a6bfcfa25.jpg
21 Comments
sirfan570
you must be reset mobile after may be got good battery result
sirfan570
my s7edge has good battery...4-5 AOT
Not applicable
sach me yaar 4baar Charging Lagana pad raha hai
whiterfang
how long does ur s7 edge battery lasts?
Nishitkohli
Expert Level 4
AOD BAND KARKE DEKHO
whiterfang
kiya..koi phark nhi.. reset bhi kar chuka hu. shyd battery ka prblm ho skt e?
iAnsh
Security patch nahi mila isiliye
lunaticfiend
iAnsh, do you keep your brain inside of your ass? Security patch and isolated battery drain issue ka kya connection hain?
kedar
same problem here my s7 edge
