praviiii
Beginner Level 4
09-29-2018 08:57 PM in
5 Comments
InsanelySober
09-29-2018 09:53 PM in
may be u have installed some app which is causing it
praviiii
Beginner Level 4
09-29-2018 10:22 PM in
almost i deleted all apps now only have default apps
InsanelySober
09-30-2018 01:00 AM in
check your internet browser for any bookmarks or check your fone for virus.
umi
09-30-2018 09:41 AM in
from settings go to apps then search for the UN similar apps that you don't have installed and install them and you will be fine
admin_
10-04-2018 03:31 PM in
We do apologize for the inconvenience caused as you are getting ads on screen. We would like to inform you kindly follow the steps below to resolve your concern:-
- Google setting>ads>opt of personalization>off.
- Google>setting>ads> Google> web page open> Ads setting> off.
- Please run your device in safe mode. If the Ads disappear in safe mode then uninstall the third party applications.
- Please do reset your device on factory mode after taking the data backup Via Smart switch and remove the Google account.
Be sure to hit ♡ when you find an answer that works for you. For further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
