s8 front camera issue
(Topic created on: 01-30-2018 09:04 PM)
sahilsingh6862
s8 front and back camera doesn't work perfectly.it doesnot focus clearly and faces in pictures are slightly bended towards one side its big problem for device.it happens with me after 3 beta update.
3 Comments
AashishYadav
camera doesn't work in selective focus mode also
Mirza83
so sad
admin_
Thank you for sharing your concern. Let me recommend some steps to further isolate and determine the issue faced by you in your device. Please be aware that device speeds may vary based on multiple outside factors.
- Check the Picture size (Camera Capacity) in camera setting (It should be Max according to Camera Capacity)
- Turn on the Auto Flash (If Available in the Device)
- Reset the Camera (From the Camera Setting)
Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
