S24 FE front camera issues
(Topic created on: 10-10-2025 06:28 AM)
PPT01
Why my front camera is giving only 7MP photo whenever I try to take and the max resolution it took is 9MP that too when I am recording in UHD from front. Does any one facing the problem or only me?
Does anyone have solution to this ?
6 Comments
942 1i ❤
In samsung don't see the resolution while using front camera, it is bad. Just see the photo if you don't like then take again
PPT01
The problem is it's a 10MP camera, but it still giving 7MP, why the resolution is decreased that much
Sorry to say but i have no idea why that is happening with your device
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
Jarvis2399
Try 3:4 ratio and also in normal lens it will take 7 MP and in widen lens it will take 10 MP i guess try it out and let me know if that helps!!
