s8 battery is draining too faster
(Topic created on: 11-11-2018 05:22 AM)
maheshS8
I observed that from past one week my mobile battery draining too fast ... it draijs soo quekly like now it will be 20% and with in 5 minutes it with in 5 minutes it will be 10%
I dont know what is the issue.. i switched off wifi and mobile data and no app is in running... what could be the problem....
6 Comments
Shiv9564
Run your mobile in safe mode to find out the faulty third party app creating the problem n delete them. if third-party apps are not the reason behind problem it may be due to bugs or its the right time to Change mobile's battery.
maheshS8
may i know how to run in safe mode.
sanjeev88
iam also facing same problem and safe mode trick is not working
YRSS
report it to Samsung they may help you
Bipinjohn
It's common with Samsung flagships when they get old . Must be a battery related issue
maheshS8
even i am also facing same issue.. hope samsung is making some bugs in updates
