s25 ultra camera problem flikkering how to fix
(Topic created on: 10-13-2025 12:40 AM)
Rahul_Pote
9 Comments
raj2828
I'm having the same problem with my s25 ultra. Whenever I zoom in, the camera starts flickering and there's a sound of the camera flickering. I don't understand what the problem is.
BiRdMaN
Send an error report along with log files to customer support through this members app, and Samsung will add/fix it in the next update. To do that, follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful, I'd appreciate it if you could ACCEPT it as a SOLUTION. Thank you 😊
Rahul_Pote
Thanks a lot.. but if I show this problem to service center.. are they capable to fix it..?
BiRdMaN
But I'm not sure whether they help or not
Rahul_Pote
Because.. alomst 8 months completed for my phone.. and if I wait for update and update comes after 4 months.. and still issue remain same.. then.. what option in front of me..?
BiRdMaN
Visit the service center
cs_member10
Dear Samsung Member,
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
YJG
My Galaxy S25 Ultra camera is facing a really annoying issue.
Shaking and noise: Camera while zooming, focusing shakes and makes a stuttering or rattling noise. And even this is getting captured while taking videos.
This is a flagship phone purchased at a premium price, and such problems are simply not acceptable. Many users are reporting the same issue, and several YouTube videos confirm it's a widespread problem that Samsung needs to acknowledge and address. Some users mentioned that Samsung Care replaced their camera module, and it fixed the issue — but I don’t want my brand-new device to be opened and reassembled due to a manufacturing defect from Samsung.
This needs to be officially recognized and resolved by Samsung.
Rahul_Pote
Yes.. need to give replace mobile
