s20+ display issue at lower brightness setting
(Topic created on: 10-20-2020 10:50 PM)
Deepak_c
I recently purchased s20+ and observed a kind of discoloration when the brightness is at the lowest setting. Is anyone facing this issue? Observed in grey colored areas only.. Other colors are perfect
18 Comments
yes I also noticed it with my S9+
Deepak_c
Oh is it. Am having an s9 as well.. But don't have this issue. Recently you observed this issue in your s9+?
yes about 1 month ago.... but I don't always use at that brightness so it doesn't bother me
TimonN
Actually these issue related to colour at very low brightness in very dark room on dark background can be noticed in almost all OLED displays.
Only difference is how much is severity of issue, even 2 different phones of same model behave differently.
But do you really use phone in such situations?
That's big question.
Deepak_c
Yup. I use. The first day itself I noticed the issue as I was not seeing the same in my S9
TimonN
Can you photo of both side by side ?
I feel this may also depend on the way UI elements are shown on 2 different phones.
I basically don't use phone is such conditions so doesn't bother me much.
Ankur14
Even My S10 lite is having the same issue
Not applicable
S20+ has this problem. Return this phone if you can. I have been fighting over this with Samsung for over two months now20200811_031501_2619.jpg
Deepak_c
I bought mine from flipkart. After requesting a replacement, the technician who came to inspect the issue rejected saying the device display is like this since its dynamic amoled and bcoz of its high refresh rate...
