02-04-2021 04:50 PM in
Galaxy S- Mark as New
02-04-2021 04:58 PM (Last edited 02-04-2021 04:59 PM ) in
02-04-2021 05:45 PM in
02-04-2021 05:46 PM in
02-04-2021 05:48 PM in
02-04-2021 06:15 PM in
02-04-2021 06:39 PM in
Galaxy S1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
02-12-2021 11:15 AM in
02-12-2021 11:25 AM in
02-12-2021 11:29 AM in
