s10 lite usb connected disconnected problem
(Topic created on: 09-08-2020 09:17 PM)
AmanHaryana
My phone had charging problem two months ago and my phone was in service center for 3 days and they had replaced usb kit/port.
And now after two months same problem again.
50k for these type of problems in just 5 months.
My phone is just five months old.
Its showing "usb connected disconnected" in repeat until restart...
Sometimes showing cable charging and also charging from one side of cable... i have tried everthing but problem still exists..
8 Comments
Not applicable
right brother agian go to service center
hd77
The problem is with the charging hardware and that needs to be replaced so visit service center and they will support for the same get your problem resolved.
AmanHaryana
but i will not keep this set... set will have to sell
chaitu197
I am using the same phn, recently I was faced charging issue.. for 1 full charge it took more than 2 hrs.. n sometimes its not getting charge also.. many times reached customer support but no use..
issue got fixed..
when I was switched to safe mode for 1 time n I uninstalled all third party apps
it workd fr me..
AmanHaryana
solution is not permanent bro...
harware to be replace. usb port is damaged
Samsung_Support3
Dear Samsung Member,
Please perform the below mentioned steps to resolve the issue:
Open samsung member app > Get Help > Interactive check > Choose the phone hardware you want to check and optimize performance(eg. ports).
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
judok1230
i tried this in the morning and it helpes ans many users were suggesting this cound be due to moisture.
1. switch off phone
2. put it in a rice(raw, not cooked) pot.as rice absorbs moisture for an hour.
3. take phone out. clean it once with dry cloth. dont put cloth inside the ports.
4. start the phone and check.
At least this resolved the issue for me.
manullah
The same problem i also facing it may be
software problem
