Resolved! Solved
s10 lite battery usage not visible
(Topic created on: 01-06-2021 04:32 PM)
anurag22
I can't see battery usage in my s10 lite it's totally blank here when i tried to check battery usage!😑
2 Solutions
Pd810
Hello,
Follow steps on this website and your problem will be resolved.
https://www.sammobile.com/news/one-ui-3-0-battery-stats-2021-bug-on-galaxy-phones-fix
Bro, if problem solved then click 3 dots near our above comments and accept them as solution to help others 👍
5 Comments
Pd810
Hello,
anurag22
thank you so much buddy it's fixed:)
anurag22
tnx buddy
