problem
(Topic created on: 04-05-2017 12:43 PM)
ranjana
facing notification and ringtone problem sometimes my galaxy s7 automatically go to the silent mode and I have to restart my cell phone to fix this problem and that time I am unable to attend online or WhatsApp call and can't play videos online.
4 Comments
Abishek
No problem for me. S7 Edge.
surajyadav
this issue is coming due to crash of os.
boot ur phone on safe mode or reset ur device once
admin39
Thanks for being with Samsung and for sharing your concern. Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device speeds may vary based on multiple outside factors. It appears that there may be a third party app or other program that may be leading to what you are experiencing. Placing your device in safe mode disables all third party apps upon startup, to help determine if the use of a third party app is interfering with your device .restart your phone in safe mode. While your phone is powered off, press the power button to turn on the phone, once you see the Samsung logo appear press the volume down key and hold it until you have completely booted up. Also, the relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
Naquiyah
I'm facing the same problem with my a5 2016. any solution to fix this?
