phone automatically switches to normal ringtone mode from vibration mode
(Topic created on: 08-12-2018 09:52 PM)
pjana
when I put my phone on vibration mode only and make a call to any number and disconnect the call my phone automatically switches to normal ringtone mode.
why is this?
8 Comments
sen001
Report this BUG
pjana
i did
DIHarshana
have any spy app or phone finder app?
pjana
Not that i know of.
nav11
reboot it problem will solve.
pjana
did but still the issue is there.
nav11
mine fixed
admin_
We do apologize for the inconvenience caused. We would like to inform you to follow the steps below to resolve your concern:-
- Navigate to apps >> Settings >> Apps >> Tap on three dots >> Reset app preferences.
- Please run your device in safe mode.
- Please do reset your device on factory mode after taking the data backup Via Smart switch and remove the Google account.
Be sure to hit ♡ when you find an answer that works for you. For further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
