not able to change wallpaper and style settings
(Topic created on: 07-28-2023 02:56 AM)
SYD221
system settings keep crashing while changing wallpaper or lockscreen layout!!! and even not able to change always on display's settings!! please help me out!!
12 Comments
Check if themes or any related Samsung app have updates available in galaxy store once.
SYD221
checked there is no update!
Goto Settings > Apps > Wallpaper Services and clear it's data lemme know if that worked.
SYD221
tried bt didn't work out but now I solved the issue somehow
pranay3105
I will suggest you that you send feedback and go to the app info if the issue is still present and clear data of the app then retry to change wallpaper which will surely help to solve your issue.
SYD221
tried everything didn't work!
cs_member10
Dear Samsung Member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. We would request you to register your concern in Samsung Members Application. So, our concern team gets back to you as soon as possible.
Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Samsung Customer Support.
paulro
I am also facing the same issue since yesterday. Did you get any fix on that ?
SYD221
did you changed lockscreen from lockstar module? if yes then try to clear data n cache from settings of lockstar and uninstall then restart yr phone if it works let me knw!
