04-19-2023 09:32 PM in
04-19-2023 09:37 PM in
Galaxy S- Mark as New
04-20-2023 11:35 AM in
Galaxy SCheck the charging cable and adapter: Make sure that you are using the original charging cable and adapter that came with your device, and that they are in good working condition. Try using a different cable or adapter to see if that improves the charging speed.
Clean the charging port: Dirt, dust, and debris can accumulate in the charging port over time and interfere with the charging process. Try cleaning the charging port with a soft-bristled brush or a can of compressed air.
Check for any software updates: Make sure that your device's software is up to date, as updates can include improvements to charging performance.
Close unused apps: Make sure to close any unused apps when you're charging your device, as they can consume battery and slow down the charging process.
Enable fast charging: Make sure that fast charging is enabled in your device's settings. To do this, go to Settings > Battery and toggle on "Fast charging."
If none of these solutions work, it's possible that there may be a hardware issue with your device's battery or charging port. You can contact Samsung support or take your device to a Samsung service center for further assistance.
04-21-2023 06:41 PM in
Galaxy SDear Samsung Member,
We acknowledge your query and apologize for the same. Please visit this mentioned link to resolve your charging related issue: https://www.samsung.com/in/support/mobile-devices/my-galaxy-device-is-not-fast-charging-how-do-i-fix...
However, you can also visit bit.ly/3l9Cksp to know how to optimize mobile charging.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application>Support>Type your query>Ask a question/Tap an error report>Send)
04-23-2023 04:16 AM in
