issue with s20 plus 64mp camera
(Topic created on: 03-14-2020 09:02 AM)
DebWB
s20 plus just bought 5 days earlier, the phone getting heated when using 64mp camera. Resulting auto shutdown of camera unit. Is it a issue with others also? Should it be looked up by the concerned Samsung personnel?
12 Comments
murlimonstar
I think there is over heating issue with phone when camera is used for video, same issue happened to me, it showed a message "phone is too hot wait till it cools to use camera" hope Samsung fixes it with software update
DebWB
yaa I also got same message but this time for still photography too with 64mp 3:4 camera.
murlimonstar
Oh tats worse, I think using ois for longer than few mins is the issue, Samsung should definitely fix this asap on such an expensive phone overheating should not be happening so fast 🤔🤦🏻‍♂️
Not applicable
bro any camera for much longer time will heat up more moreover the the more the pixel more the heat is
DeepBhansali
it heats up just after taking 1 photo in 64 mp
arunsn
using s20 with no such issue
DebWB
normal camera mode has no issue, but 8k recording and 64 mp still photography causes excessive heating.
DeepBhansali
my huwai honor was far better in selfies dual camera in front what a great phone it was and never had heating issues. Even when I clicked photos for 3 hrs.
Not applicable
bro even you use 4k for longer time it will heat up more over in those video resolution the pixel size are bigger it will definitely heat up.
if you want the advice then I would suggest it to record the video at 1080 p for avoiding heats
