in galaxy s20fe battery draining is too fast
(Topic created on: 01-02-2021 08:23 AM)
gowdalakku
Dear team.
Kindly fix the battery draining and itw faster draining asap.
Kindly fix this asap. Unable to charge twice in a day . First time I'm facing this kind of issue in Samsung
gowdalakku
thanks brother
Ehsank
just do those settings i m sure you will get noticeable difference 🙂
gowdalakku
recently purchased last month 21 st only and facing battery draining issue after update of Android 11
cs-member13
Expert Level 4
Dear Samsung Member,
Please be assured and to resolve "Battery drainage" issue kindly follow the given below step:
>>Battery optimization:-Settings>Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report)along with screenshots, short videos and error log file, so that we can assist you accordingly.
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
Ravinder18
Same here in S20-FE-5G
Ravinder18
Adaptive brightness feature is caused of draining battery after updating Android 11 by Samsung so please keep adaptive brightness off.
dsr1
Iam also facing battery drain issue after the recent upgrade on Oct 01
suhaas18
Pls can u fix the battery drainage prblm in s20fe i have buy this phone for abrod country bcz of its processor nd battery but i have problem in battery drainage pls req u to fix this as soon as possible🙏
mdibattma2022
Beginner Level 3
I have the same battery draining problem with my new s20 FE.
Trivibes
Plz help battery drain to fast in s20fe
