how to enable slow charging notification
(Topic created on: 08-30-2020 08:41 PM)
sugb
Can anyone tell how to enable slow charging notification when charger is not connected properly actually i clicked on "don't show me again" option and now m nt able to find it again plzz help
17 Comments
sugb
bro no picture
Goldychahal
this setting???
Not applicable
aisa notification kab dikhayega goldy bhai ?🤔
Goldychahal
jab aap computer usb ya low ampere usb pe lagao ge😁😁
sugb
yes but nw this is not showing as a pop up notification bas notification bar m show kar raha h pehle separately notification ata tha
Goldychahal
change settings to alert
sugb
bro m using s9+ there is no general notification category in system UI
Chuxtin
IDK if you have resolved this problem, but I'm attempting to fix the same thing. This didn't work on my phone, but maybe it'll work on yours. Go to settings and enter "fast charging" in search bar. Open that, unplug if plugged in and then disable Fast Charging then enable it again. Apparently that works for some people, not my A21 though lol.
