allo
01-06-2018 05:10 AM in
How to use the call forwarding option in s8 plus
5 Comments
shadulikannur
01-06-2018 10:39 AM in
open ur phone application,
open seettings,
open more settings then u get call forwarding option...
thank you
open seettings,
thank you
allo
01-06-2018 04:25 PM in
more settings as in more connection settings ??
shadulikannur
01-06-2018 05:25 PM in
first open ur phone application...
then open settings in phone application...
then open more settings in phone application' s setttings.. u can see the call forwarding option
shadulikannur
01-06-2018 05:26 PM (Last edited 03-14-2019 02:49 PM ) in
see this
admin_
01-07-2018 01:23 PM in
Thanks for being with Samsung and for sharing your query. We would like to inform you that kindly follow the below step for call forwarding:
Kindly go to phone>>3 dot >>settings>>More settings>>Call forwarding.
We would also like to inform you that call forwarding also depends upon the network service provider. Suggest you to once contact the network service provider.
Be sure to hit ♡ when you find an answer that works for you.
