Resolved! Solved
found some replacement tips for my s24 ultra spen
(Topic created on: 05-28-2024 08:42 PM)
Darkvader12
i found some of the replacment tip for s24 ultra the metals has anyone used it yet ?
I think the plastic Spen was going to nicely compatible for your device like our default Spen comes with the device.
12 Comments
Too... costly🥵
Darkvader12
yeah i know but did you used the metal tip on any of your devices ?
No... not yet, but I think the metal tip will be too harsh on the screen 😬🤔.
Darkvader12
yes that is what i am asking about i was browsing the web for the replacement tips for my s24 ultra and i found this one so i was bit confused regarding this one so i am asking about it which nibs are better for the screen should i go for the regular rubber ones and the plastic or the metal ones like copper and titanium this the reason i posted this
Is your existing Spen was damaged or something?
Darkvader12
oh yes my spen nib is wearing off so yeah that is the reason i am asking it
Darkvader12
so should i go for the plastic ones rather than the rubber ones if you suggest me better
Darkvader12
thanks
