fingerprint sensor not working after putting tempered glass on s23 ultra
(Topic created on: 09-12-2023 10:18 PM)
ashbaj
I am unable to use fingerprint sensor after putting the tempered glass on my s23 ultra smartphone. requested to Samsung to fix it via update or do something.
10 Comments
Ansh619
You have an option to increase touch sensitivity in settings... turn it on & try. If that doesn't work then remove the screen guard. Go to a shop that has experienced sellers & ask them to give screen guard with proper touch identification.
