facing problem with gpay s23 one ui 7
(Topic created on: 05-11-2025 07:45 AM)
buddha135
s23 one ui 7
using navigation buttons (not gesture)
while on the screen at the time of entering upi pin while making payment or checking balance, bottom nos. of keyboard is getting merged with navigation buttons. this happens only with gpay not with paytm. sone issue between gpay upi app keyboard and one ui 7
any solution?
4 Comments
cs_member8
Dear Samsung Member,
As you have mentioned that you are facing the issue with third party apps and if your device other application working fine, So we would request you kindly contact the respective helpline to make sure there is no issue from their end.
However, If still facing the same issue, kindly share the log file. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
buddha135
thanks
ravikumarjoshi
This is still an issue
