experiencing technical difficult On WhatsApp call volume buttons not working
(Topic created on: 06-22-2024 02:21 PM)
ArifKhan000
I am experiencing technical difficulties with the volume buttons on my WhatsApp calls S24 ultra .please fix this bug
cs_member10
Dear Samsung Member,
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
The clear cache memory of a particular application:
Settings > Apps > Now pick the app you like to clear off the cache memory > Storage > Clear Cache.
Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
Keep your app updated: Tap on Google Play Store app or Galaxy Store> Manage apps & device> Apps available to update> If you want to update apps individually, tap See details and then tap the Update button next to the app you would like to update.
Note: kindly contact the particular application helpline once, to make sure there is no issue from their end.
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
