Resolved! Solved
edge lightning
(Topic created on: 04-24-2025 05:02 PM)
salimkhan666
i have updated my s24 ultra yesterday but the edge lightning notification is not working how to fix that please hlep me out samsung team.
Timothy2
Expert Level 4
Hey, try it and I have slove your problem,could you mark this as resolved? It would be great. 🙏
9 Comments
Timothy2
Expert Level 4
Download Good Lock app-There you will find-Routine+ Download it...1st
Timothy2
Expert Level 4
Timothy2
Expert Level 4
Timothy2
Expert Level 4
Thats all you need to follow 🙏1745495118578.jpg1745495118599.jpg1745495118623.jpg1745495118643.jpg
Timothy2
Expert Level 4
bhaghwan
Thanks from my side too..can you send screenshot of some edge lighting.🙏
Timothy2
Expert Level 4
Pls mark as resolved🙏
bhaghwan
😂.. it's not my post so I can't
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
