display issue for my s10
(Topic created on: 07-14-2020 11:31 AM)
savio96
My s10 display started showing greenish yellowish fade 3 months back.
And now at brightness level from 20- 70% its show horizontal lines all of sudden.
There has been no external damage to the phone whatsoever.
Also I'm in warranty but I'm unable to get to the nearest store due to lockdown.
12 Comments
MohammedSijah
Hi, I think this is reported by some other users also.
You may send an error report. For this,
press the 'Get help' tab from the Samsung members' homescreen. Click on 'send feedback' and then on 'ERROR REPORT'.
Describe your problem in detail. Attaching a screen record or screen shot is best. Make sure you have good internet connection. Don't close the app till the log files are uploaded completely (anyway you can minimise the app).
They will reply within a week.
Thank you.
savio96
I have done it.
but screen recording or screenshots come normal, you cannot identify the issue.
MohammedSijah
That's an important hint for them. I thing you have included that in the report. Anyway I think screen shots may not be required for this. They will ask for that if needed. You can click 'text- chat' also, for instant feedbacks. Share with us your results. Thank you.
savio96
yeah sure Sijah !
I hope they do revert back
jijojoseph1
try to ........change the display mode settings and colour adjustment........u can solve 50% issues.......dark mode and white mode also try
savio96
checked it out
color adjustment doesn't work
but if you switch to dark mode the lines are not visible. it looks normal
but thats the temporary solution.
jijojoseph1
try one more .......*#0*# then check the colour combination.......update one ui home app also
Samsung_specialist
Hey there,
This is issue is preferably to be checked by our team in the nearest service center.
Which country are you in?
savio96
India ,had brought the phone from uae
but I'm stuck here due to lockdown
